You can test the injectors with an OHM meter.
You need to test all 4
Allowed range is 11-18 ohms
They should be about 14.5 ohms
This only tests the solenoid in the injector, not if it is sticking or clogged, but you would usually get a CEL and OBD code if one injector was acting up.
When you tested fuel pressure did you unplug the vacuum line on the FPR(fuel pressure regulator)?
At idle fuel pressure should be about 35psi, and FPR is open(high vacuum) to send fuel back to the fuel tank.
When engine is under load, using more fuel, the vacuum pressure drops so FPR closes which keeps the fuel pressure stable.
If it is not closing then fuel pressure might be dropping to the point where engine is stumbling.
So with engine at idle and fuel pressure gauge hooked up, pull off the FPR's vacuum line(put finger over the end so engine doesn't see a vacuum leak), this is just like engine was under load, fuel pressure should jump up, 5 to 8 psi if I remember correctly.
If fuel pressure doesn't change replace FPR.
MAF sensors need to be cleaned now and then, this sensor tells the computer how much fuel to use based on the air coming into the intake manifold.
If there is a leak in the air plenum(big plastic tube from MAF location to intake), then the MAF is telling the computer the wrong information, extra air is coming in from the leak so computer is running engine leaner than it should.
