richard89
I have an 89 ranger 2.9 that appears to have the check valve in the pump stuck open. I have fuel pressure to specs with the engine running but as soon as it is turned off the pressure drops to zero. I have no fuel smell in the oil so the injectors are probably OK and the vac line to the regulator is dry. I have to cycle the key on/off 7 or 8 times or crank for about 10 secs to get the engine to start.
Has anyone tried to free the valve by blowing 5-10 psi air into the fuel line at the filter inlet? Anyone know of an additive that might help?
