WisdoM
It started with it sticking @ 3000rpm once in a while after it was well warmed up I just had to slam the padal a couple times and it would come back to normal. I checked the cable and thottle body...everything seems to move freely with no binds. since I dont use it I disconnected the cruise control cable to see if that was the issue and its not. So now once in awhile it will stick @ 5000rpm and not come back down, I have to turn it off and physically push the throttle closed at the throttle body....would the TPS do this?
