Peregrine
Ok... I had a worn ball joint on my drag link that caused a lot of slop. I very carefully measured everything, and replaced the drag link. Got it all back together and everything tracks straight and seems to be the same on the measurements. However, my steering wheel is rotated about 10 degrees or so to the left (counterclockwise).
Went to just pull the wheel and move it a few splines over, but discovered it's not a splined wheel. Any suggestions as to the fix? Did I actually screw in the drag link too far on the passenger side tie rod or maybe not far enough? Any other suggestions?
