steering wheel cocked
sliding 2.9 89
i put an aftermarket steering wheel in my truck and it is cocked to the left. is there any way to disconnect the steering colome from the box and turn ot and re connect it.
yes. but I'm not 100% certain if the lower steering shaft has a flat spot on it or not...if it does the 2 parts will only go together 1 way.
Get an alignment and they can correct the steering wheel (assuming its only a few degrees).
Yeah, if it's only cocked a little bit (<45°), it can be corrected for at the steering linkage on the axle.
It cannot be repositioned on the column however (or reindexed at the box).
