Steering Stabilizers
Tx03edge
Has anyone put a steering stablizer on a 2WD Edge...if so do you have any pictures?
Does it really improve the steering that much?
Thanks in advance:icon_thumby:
Steering stabilizers will NOT work on the '98+ Rangers. The '98+ Rangers use a rack and pinion steering setup where the '97 and older Rangers use a steering box and tie rod setup.
If you have bump steer with a rack and pinion setup, you have problems that needs to be fixed.
Rack and Pinion:
I was wondering this too, but i have a 95 2wd. where does it mount? I may or may not run one, i'm just curious. thanks in advance
steering stabilizers are nothing more than a band-aid to hide poorly-set up steering geometry. my advice: use the proper drop pitman arm or run a pre-runner style steering setup and leave the steering stabilizers to the mall-crawlers.
sweet my steering is fine, i just wasn't sure what the deal was, thank you!
