Rustbucket350
- Jun 17, 2016
Took my Bronco II in for an alignment after lifting it and it's very hard to control the steering. I do have a dropped pitman arm and axle beam drop brackets. He got the toe and camber in spec but the caster is still -4.9 on the left and -8.8 on the right. He wouldn't adjust it further because the wheel bearings are loose on one side. Now, I know my tie rods are all bad and it never drove great but it did still drive and steer on the highway. My plan is to replace the tie rods, tighten the wheel bearing nut since I know I forgot to snug it, and get them to fix the caster.
Is there anything else that would cause it to dart all over the road?
