steering hobble at speed
Viper Command
Crestline CA.
2x'97-'88-'98-'
I live in the mountans, last month I noticed slight steering shemmie when turning left at 60mph (sweeper turn) also when I backed up camber would go positve and toe in, and last week I noticed any left turn at 45mph+and would feel like my truck had lost its lug nuts. my lower ball joints where beyond shot, I replaced all 4 upper and lower bolth sides. now it shimmies right and left also when I back up camber goes positve and toe out.
the truck has 4" coils, rad. arm drop, and 6 deg camber slugs. wheel bearings are also new and ajusted to spec.
could all my problems be the 4 ball joints in the steering linkages?? there is not much play at all. am I missing something?
Sounds like it needs a wheel alignment if the camber is jacking when backing up. WHen you changed balljoints did you move the camber/caster shims in the upper balljoint?
I took notes on all of the ajustments before disassembly, and remeasured to verfi after install. alignment is dead on, the steering wheel is straight, travles straight w/ no hands on the wheel, no pull.
see im at a loss!!!!
also the problem was current before I replaced the ball joints
update I just replaced all 4 tie rod ends. problem is gone i will be gitting it on an alignment rack very soon. damn its so smooth.
