Hey folks,
I've been reading the forum for a long time while I keep my little truck alive.
Recently I decided to breath some new life into her, starting with my increasingly dangerous steering. Any mechanic I've ever been to says they can't figure out what the problem is. Over the years I've changed tie rods, ball joints, wheel bearings. Drag link seems fine.
In a bit of frustration pulled the steering gear and it didn't seem like anything was wrong. However intuition told me to look inside. Besides some wear on the gears (which may turn out to be meaningful, I can't say yet) there was some obvious shrapnel inside, just under the cover. It seems to be coming from around the adjustment screw.
Has anyone ever seen this before? Was there once a bushing on that screw that kept it centered and has now been worn to shreds? I can't find a rebuild kit that includes the bolt and whatever else is associated with it. It does feel like there is spring pressure behind it, but the thing is just floating. Is this play contributing to my steering slop somehow? I'm a bit concerned to have chunks floating around in there.
