Bronco648
- May 23, 2019
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 15"
Ranger: 1985 regular cab, long bed.
Drivetrain: 2.8 V6 w/A4LD trans.
Situation: engine & tans. out of the truck. Power steering pump removed and is obviously leaking based on the fact that both pump, lines and mounting bracket are covered in fluid and grime (as is the steering gear - still in the truck).
I plan to replace the pump and lines but am wondering how to determine if the steering gear might also be leaking. If it is, I'm inclined to replace it with a manual steering box and do away with the power steering pump entirely.
So....
1 - Can the steering gear be checked for leaks? If so, how?
2 - Can I switch to a manual steering gear and do away with PS entirely?
TIA, Dave.
So....
TIA, Dave.
