Steering Box Swap
dabomb5756
Owensboro KY
I have an 87 bronco ii with 2.9 and power steering. Looks like i might need to rebuild or replace my steering box.
What years can i use? 83-97 ranger/bronco ii/explorer box? Are they all the same or do i need to find another box specifcally from a bronco ii?
Thanks,
Neal.
I have heard of some people using ones from f-150s. But I do not know what is involed with that. You could always get a used one from a scrap yard. Rebuild that and than swap it in. Less down time for your truck.
I got one from an early 90's f-250. All bolt on, different gear ratio though. Just look at yours and go to a junkyard. Find one that is still connected to the pump so that you don't have years of dirt collected inside it.
Sent from my SAMSUNG-SGH-I547 using Tapatalk
'83-'97 Ranger
'84-'90 Bronco II
'91-'94 Explorer
'80-'96 F-150
'80-'97 F-250
'80-'97 F-350
'8?-'97 F-450/F-Super Duty
Possibly some pre-'97 Econoline vans also?
Lots to pick from regardless.
Lots to choose from, should be able to pull one from the yard. Thanks junkie.
Pretty much any pre-2000 Ford with a recirulating ball gear box should work with little to no modification.
faster or slower? going to assume slower for more push vs speed..
