So the 2 wire one would be the sending unit then?
The 2 wire ECT SENSOR is for the computer only.
The 1 wire sender is for the dash board gauge, << this one is easy to test:
Find it..............unplug the 1 wire from the sender, turn on the key
Gauge should show below COLD
Now Ground that 1 wire to the engine or Negative on Battery, use a short wire if needed.
Gauge should then move to above HOT
If these movements happen then wire and gauge are working, sender is bad.
It would be better if you posted the actual code numbers, not what you think they mean or what a website thinks they mean, you are probably 100% correct on the meaning but.................trouble codes can often bite you in the butt if you take them at face value, lol
