Won't turn over or won't fire? If it won't turn over and the starter, solenoid and battery are good, then it may be something odd like a bad ignition, or neutral safety switch.
In order to isolate the problem you could first make sure it's in park or neutral with the parking brake on then jump from the small prong on your starting solenoid to the + battery cable post on it. If you do this and it turns over then your problem is on the control side, and you can trouble shoot from there. If it doesn't then the problem has to be in the cables, grounding, battery, solenoid, or starter.
If it turns over and just won't fire. Let me ask you a question did you leave your key in the on position with engine not running for any length of time? I did this right after my duraspark conversion and it burnt out my ignition module. So start by testing that out. Hopefully I'm wrong but check it out, Autozone will do it for free. If not then go back through the usual checks spark fuel, timing. Good luck, and let us know.
