Lukeinthewild
Hey all, I'm new here. I'd say I'm a Saturday mechanic but that's a little generous so I'll say I'm learning and would like to understand more. I live out in the Bush (off the road system) of AK so resources are limited, though I can fly parts in within a few days.
The issue on 2001 Ford Ranger 4.0- won't start in the cold (multiple attempted fixes below)
I have had intermittent starting problems with the truck since last Fall. Sometimes it would start up first time, other times it would take multiple cranks. The problem got worse and the truck became much more unreliable. Looking back I'm not sure if the colder weather was the factor or something else. Maybe both.
I noticed my EGR sensor was fried (literally melted) and I replaced that. The starting irregularities persisted.
I didn't know the last time the fuel filter was changed so I replaced that. My problem was resolved immediately. Then it happened again as it got colder.
I checked the fuel pressure (off the rail, in the cold) and it read zero.
A friend helped me tow the truck into a heated airplane hanger and I checked the pressure again on the rail and now it read 62-63psi and the truck fired right up. I put some HEET in the tank to try to eliminate any moisture and drove the truck for quite a bit afterwards. No success. The truck wouldn't start after it was freezing out.
Thinking maybe I had water somewhere in the fuel system and that it was freezing, I decided to check the fuel tank (our fuel out here goes through multiple different bush containers and thought they could possibly have moisture in them by the time they get out here) and pulled the truck bed and the fuel pump to check the tank. I saw no evidence of water in the fuel tank but because it was original pump (150000 miles) I replaced the full sending unit. The truck started right up after replacing sending unit BUT again I was in a heated hanger.
When I parked it outside at my house and it froze- it wouldn't start again.
(Forgot to mention that I put in a new battery last year too as well as changing spark plugs.)
I tried looking into the problem again as it's been a little warmer (20's-30's) with no success.
A friend of mine came over to help me diagnose as I now had new problem as now it wouldn't crank like it did before. He thought starter. (We fully charged the battery after it sat for a while) He hit the starter with a hammer with no success but thought he could here the starter trying to engage but we couldn't get it going. We also noticed the 'full starter' fuse in the fuse box was clicking loudly when we tried to start it this time. We switched the fuses in the fuse box but it didn't make a difference. I have a new starter and new fuse ready to be installed when the temperature warms up so we can work on it again.
I've obviously spent a bunch of money throwing parts at this problem, to which I'd like to not keep doing, but am at a loss.
Any other thoughts would be appreciated. Thanks for reading my long post.
