top4874
- Jun 11, 2013
- Automatic
I have a 92 Ranger that is having starting/running issues.
Truck ran fine until the weather started to warm up. When I would drive it for any extended it would randomly die. Would start right back up, but eventually got to where it wouldn't start. Had it towed a few times and as soon as it came off the rollback it would start right up every time.
A friend told me to check the purge valve on the fuel rail and see if gas was making it to the injectors. I got an Allen key and pressed it. Nothing but air came out.(after one of the times it stalled on me.) It started right up after doing that and drove fine for about a week before it happened again. Same situation, same fix... So, I was told to replace the canister purge valve. Did that and ran fine for a week. Same result, but this time bleeding the fuel rail didn't work. Had it towed home.
As soon as it comes off the rollback, it starts right up. Rollback driver said he has had several do that when the fuel pump goes bad. So last night I replaced the fuel pump and fuel pump relay. Started fine and ran fine until about a hour ago. This time it was driven for about 20 minutes and parked for about 3 hours. Wouldn't start. Was told that if it wasn't the fuel pump that the ignition coil had to be bad, so I replaced it. Still wouldn't start.
So I got the bright idea to rock the truck back and forth to see if I could "trick" the truck into thinking that it was just put on a rollback. (silly I know) Started on the first try. Drove it home and now don't know what to do.
I can't afford to replace everything that "might" be wrong with it. I have replaced the plugs, wires, cap, rotor, Canister Purge valve/solenoid, Fuel Pump, Fuel Pump relay, and the ignition coil.
I would greatly appreciate some pro knowledge because the "knowledgeable" guys at the auto parts store are breaking me.
