2.8broncoII
- Aug 9, 2007
sometimes when we go to start her truck you turn the key all the lights light up and radio turns on but the starter wont turn over. so i climb under the truck wiggle the red wire around on the starter then it will start and is fine for afew weeks. then it happens again and i fix it the same way. im thinking there is corosion on the terminal? should i replace the whole wire? die-electic grease?
where does this cable go?
where can i get one?
what is it called?
and is it hard to replace?
thanks all,
dan
what is it called?
thanks all,
dan
