davemmiller
- Mar 28, 2010
If the white wire attached to the solenoid goes bad, possibly a break under the insulation, what kind of sound would you hear when trying to turn over the engine? Would it be a whirring? I went through 3 starters from Autozone. I installed them, turned the ignition and all i heard was the whirring. Each time i returned to Autozone and they tested each of them. They all worked fine.
My guess is the starter is turning but not engaging due to a possible bad wire.
The only other thing would be the starter relay but it is not located where the ol' Haynes manual says to find it.
Any help would be greatly appreciated. I do have a new wire i could run but i am not sure where the one connected goes to.
Thank you,
Dave
Thank you,
Dave
