- Mar 24, 2008
- Age
- 45
- Howard City Michigan
- Automatic
92 ford ranger 4x4 4.0. Problem, starter worked fine, then it didn't work at all, doing nothing in between all with in 2 hours. We put a tranny in the truck and in the middle, we started the truck to test the tranny starter worked fine. When we finished the install, not touching the starter since before, it didn't work anymore. So I pull the starter down, leaving the wires on, push it up the the engine as a ground, hit the key and the starter rolls like it should. SO then I put it back in, hit the key and nothing.
What should i be looking for? Is the common and if it is, what causes it? Is it time for a new starter?
thanks
thanks
