Starter Issue
mtipton
Solid Axle Swap
Vancouver BC
hey guys,
I'm having this problem with my starter, the truck turns on fine and everything, but the starter stays engaged for maybe a second or 2 after the truck has started then it will stop everytime. i thought maybe it was my starter but no that wasnt the problem, the relay on the fender, i changed that as well, as with the ignition switch because it was a little sticky
if anyone has somewhat of a clue on what is going on here, your help would be appreciated
Part of the starter
hey guys,
The part that engages the flywheel is the BENDIX, The bendix has a return spring in it that makes the gear come back out of the flywheel when the electricity to the starter is turned off.
Big JIm:hottubfun::wub:
is the bendix a part of the starter itself, or is a lone part
okay, i looked it up, apparently the bendix is a part of the starter, which is basically the starter drive.
it just seems odd that the problem would be that due to the fact i replaced the starter when i bought the truck, and had the starter warrantied because i had though the starter was a faulty one, but when i changed it again there was no change
