yellowoctupus
Is heat soak a common issue on the 2.9 engines? I have noticed recently that I can start my truck over and over again, as long as it does not come up to temp. If I'm out driving long enough for it to warm up, after shutting it off, it will rarely spin over enough to start the engine. After it cools off again, it will fire right back up. One member (in a gen. forum search) mentioned oil on the starter helping heat soak. While I'm not sure how this would be so, has anyone else had this problem? Am I missing some sort of starter or exhaust mounted heat shield?
