- Dec 26, 2007
- Age
- 40
- moving with the army
So I installed an s2000 start button where my broken cigarette lighter was. it looks pretty factory and only took about 30 minutes to install.
Ok, here is a quickie on how I did it. I used an S2000 start button. to make it fit you have to file the ribs off the side and use a file to enlarge th lighter hole a tiny bit. you use an old floppy drive power cord to plug into the back of the switch, it fits great.
And here is how it all wires up. if you use th top yellow wire on the column harness for the 12V+ then it will only be powered when the ignition is on.
