- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
B&M sold a clutch hydro trans for drag racing in the days before high stall convertors. Some of the early automatics were horribly inefficient- Buick dynaflow and chebby powerglide come to mind. Ever drive a powerglide? They have basically 2nd and 3rd(direct) gear with a loose convertor in front of it.My brother had a 67 Camaro with a 327 and a powerglide. I put an RV type cam in it with a Performer intake and a 600 Holley. With the powerglide you could mat the throttle from a stop and not spin a tire, once I put the turbo 350 trans in it, the tires would go up in smoke. Newer automatics are often more efficient than a manual trans, primarily thanks t lock up torque convertors and more gears with closer spacing. I'd still rather have a clutch pedal, I guess I'll see how this Ranger works with the C4.
