Wes
Looking for clarification on some conflicting information...
In the tech library there is an article titled Dana 28 & 35 Specifications. In the table, column Dana 35 and row Factory Ratios it lists 3.21, 3.55, 3.92 (IFS). I have a 98 (IFS) however the tag on my Dana 35 says 3.73 with the rear matching. So my question is... Is this table wrong or did ford put an earlier model Dana 35 (reverse rotation) in my rig? I don't think so because the sticker has part number 610556 which the article refers to as a FORD 35 FRONT 1998 EXPLORER - NON DISCONNECT (SLA IFS).
I ask these questions because I'm planning on changing my gear ratios to accommodate bigger tires and don't want to buy a standard rotation gear if my front end uses a reverse rotation gear.
