Lift
It seems to be that this v8 swap is just one problem after another, Now that i finally got the clutch taken care of i have been able to test drive her on the road. The only problem i seem to be having is the engine will die when downshifting or coming to a stop and its completely random.
I checked the timing, i checked the carb idles settings and adjusted them all the way in and out 1.5 turns. All the vacuum hoses look to be good.
The only thing that may affect this is im using and aftermarket jacobs ignition with an efi distributor on a carbed 302.
Im not sure what else to do about it i cant seem to fix this problem. I need someone with more professional experience then me to give me some insight on this or possibly even take a look at it thanks.
