Talmadge #@87
93 3.0 ranger has two flat circles on passenger side of block plugged with metal cap. One is f'd squirting water what are these plugs and how do you remove them?
Thank You. Thank God for RednecksThe holes measure 1.49". So I guess that is the 1 5" size. Tap new ones in with hammer, carefully.
In the freeze plug hole????Put a 2.9 in it
This. I had the (mis)fortune of doing both of the plugs. 1.5 is your man but make sure you use metal and not the rubber expanders. The expanders will work but they also don't hold together. If you have to use one then make sure get some threadlocker so the nut doesn't start trying to back off and loosen the plug.The holes measure 1.49". So I guess that is the 1 5" size. Tap new ones in with hammer, carefully.
