squeezing another 2 inches in the front?
swynx
lewiston idaho
Got my leveling spacer today from fleabay. Made me start thinking. Now I wanna find a way to lift the front another 2 inches and run belltechs outback . This rig hardly sees road use.
Was thinking f150 coils. Or a leveling coil. Idk if f150s will work with mt new coil spacers? But Im just starting to understand ttb. I think id have alignment issues? The camber is way off right now. Its leaning in.
The coils are stock and have 300k on them and I'm replacing all the front end parts at the same time. So I wanna make sure I get it right before I get it aligned and the 33s on it.
Thanks guys.
im pretty sure if you go 4" using spacers/springs in the front without some sort of drop brackets you will have some serious alignment issues. i doubt it could even be aligned. i dont think the aftermarket eccentrics will even get that much out.
That's what I started reading. Ill just wait till my lift comes in next month
Not only that, but the axle beams will be on funny angles, so the tires will actually sit under the truck more than usual. Not a good thing from a stability standpoint.
