Squeaky Coil Springs
easye
Okay, i put one of my lift coils in today and took it for a test ride and it squeals like a pig. I took it out again to make sure it was seated properly and took it for another ride and it still squeaks but not as bad. Im not sure what to do, there are two holes at the bottom of the coil bucket where the end of the coil is supposed to be and its there. Could i twist it around some or would that be a bad idea. Thanks
if you used a daystar spacer give it a few days to break in then it should be ok
when i put my new arms and springs on my 99 it makes a grip of noise now and also my springs rubbing against my coil buckets due to the angle they are at are making alot of noise too, ive head spraying cooking oil on them will somewhat help but it sounds kindve rediculous to me, i actually took my truck off the pavement for a while out to ocotillo and the rough riding actually helped get some of the pops out and helped wear in my springs so that might help
mine did the same when i installed my spacers
i had to put some "C" shaped rubber(really thick rubber) pieces on the spring bottom, on the outer side to correct the arching angle they had
