Zorro
- Mar 10, 2008
- Automatic
truck is a '94 4.0L, 130k mi, 4x4 if that makes any difference. I also swapped to a manual transmission a couple months ago, and I did swap the ecu as well.
Coming back from work (15min), it started sputtering towards the end of the drive. It would sputter if more than 1/4 throttle was applied (or thereabouts), but do fine as long as I wasn't stepping on it.
Back home, I checked the plugs, they're white, fuel starvation.
Could it be the fuel filter? fuel pump? injectors?
I'm not out of gas, gauge says I'm half full ... although I tried adding a gallon (from a little red one gallon tank, not gas pump) ... and it overflowed after half a gallon. No idea where that came from, but there was no way to get any more in ... and I'm positive it's nowhere near that full.
Bottom line ... help out a pour soul out there
TIA
TIA
