Muddytruckn
- Aug 4, 2014
I'll be in the market for some new springs soon & am looking for advice. Here's what I need them to do & what ideas I'm bouncing around at the moment. I've searched quite a bit & still trying to gather more info.
Currently my Bronco has a 3" BL, stock suspension, 28/7.5 axle combo with 4.10s. I know I could use some new shocks, but waiting until after I find the right springs. I drive this to work 2-3 days a week & until I got this Bronco that struggles everywhere, I went offroading on a regular basis (I'm working on some solutions to the weak offroad performance). Anyways, I'd like to get another 1-2" of clearance without killing flex or adding spacers if possible. I'm aware that my factory springs are probably shot since the rear squats bad every time i hook up my 4x8 trailer.
Here's some of my solutions:
Front
Explorer 4 door springs - I hear they ride rough, no flex
Early STX springs - Anyone have a real replacement part number or know where to find a set? I'm sure these would be exactly what I'm wanting if I knew what to look for. Possibly even just the spring rates, installed height, diameter, etc.
Aftermarket MOOG springs - Looks like the factory # is = cc836, so what would cc842 or cc866 do? I'm afraid the cc866 would be too stiff, but I'm no expert. The spring specs can be looked up on MOOG's chart or I can post if needed.
Rear
Explorer springs - Again, worried about lack of flex & rough ride
Longer shackles - Would guarantee lift & since the springs are worn I'd be pretty flexy with my rear sway bar disconnected, lol
Not a fan of blocks, but would consider. I just feel that they would put additional stress on the springs & risk breakage.
BII/Expo bastard pack or an add-a-leaf? This almost seems like the best route.
I don't really need to go much higher for the places I wheel. As of now, I rub while turning on 31x10.50 ATs with an 8" wheel 3.75" BS and drag the rear bumper on certain obstacles. All I need is just that little bit of extra clearance to make me happy. I plan on going with some aggressive 31-32" MTs & possibly welding the rear since I can't seem to find a good 7.5 locker.
Suggestions?
Front
Rear
Suggestions?
