Spray on undercoating
Brandon12
Snohomish, WA
Im in the process of redoing my interior in the ranger. Everything is stripped, sanded down, and ready for paint. I bought a few can of rubberized undercoating and a few cans of spray on bedliner and was going to do a combination of these. However, after reading some things, it seems the rubberized stuff stinks, wears fast, doesnt dry, and has other problems. Any personal experience with this so I can at least have some good sources for the info? If it does suck, I will just use bedliner all around inside.
I used the rubberized coating on my Suzuki Sammi and it does have an order to it. After about a month it started to smell better. It does work great and helps keep out water leaks. If you prefer and can afford it, just use the bed liner spray or roll on. It will be better in the long run. Hope this helps you out, Bro.
I will be using rustoleum bedliner spray. But yes, that does help. Thank you. Maybe I will go return those cans of undercoating
ive used both and prefer bedliner over undercoating.
Dont use the undercoating. My buddy spray his floor with that, the car stuck for months.
Ok thanks guys. I will get rid of the undercoating. I'm not too worried about noise. I wanna hear that v8 rumble anyways. :3gears:
Use it under the truck, where it belongs.
Sno, is your past tense broken?
LOL!
Nope, I was on 2 year old patrol. Trying to keep an eye on her and trying to type just doesnt work.
