bert296
i replaced my u-joints in the front axle and when i took the spindle off the passenger side all the needle bearings from the spindle bearing fell all over the ground so clearly i replaced that also but now theres a really bad growling noise coming out of it... what should i have used to grease it? and how should i have greased it? i used multi purpose hard grease and packed it in similar to how u would do a wheel bearing
also the old bearing had worn a slight grove in the axle is this going to make the axle not ride in there properly and just ruin the new bearing?
