speedometer ?
dannzx6
Hi, I need some info in how to make my speedometer work whit my 5.0 convertion,not using computer. Hi,I need some info in how to make my speedometer work whit my 5.0 conversion, not using computer.5 speed manual trans.T5.Any help will be appreciated.
Take the speedo cable, stick it in the speedo hole, use the lil fork and bolt to keep it in the hole. You're done.
:icon_confused: Convertion ? :nono: "CONVERSION" ------------------- Whit ? :nono: "WITH" :buttkick::buttkick: :bye:
...and by "cable", I believe he means VSS, the electrical connector on the side of your stock Ranger trans, with a gear on the end. I don't think you '95 has a cable, but the connection to the trans is exactly the same.
Sorry baddad, you know that would have been the next question... ;)
:icon_confused: Never crossed my mind. :icon_thumby: Might be it runs off the rear anti lock brakes like my 95 E150 van did.
The rear VSS/speedometer started in Rangers sometime in '98 or later.
My '92 had a VSS and cable in the trans, my '97 has the VSS/no cable in the trans.
The Rangers with ABS have the ABS sensor in the rearend, and this controls the speedometer in later models, as mentioned.
