Yes, if cluster has speedo cable then just one option, transfer case
And even if its an electric speedo just one cheap option transfer case, VSS in speedo hole in transfer case
You would have to spend $90-$125 to convert ABS sensor to speedo pulses per mile, Ford only did that for 3 years(1998-2000) because its a stupid idea, and same years for Pulse Vacuum Hubs, "the lunatics were running the asylum"
BW1356 should have a 7 tooth DRIVE gear on the output shaft
4.56 rear axle ratio
33" diameter tires
Would need a 19 tooth DRIVEN gear, it calculates at 19.48 teeth
32" tires 20.09 teeth
