- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
I just swapped out my whole drivetrain except the engine and transmission, my speedo is WAY off. It was close with the 31's and 4.10's with the white gear in the transfer case but is reading fast now.
Current setup:
35" tires, 5.13 gears, manual 1354 with red gear in case, pink gear on speedo cable.
looking at the tech library I have a 19 tooth gear on the speedo cable, the table only shows up to 21 tooth gears, are there gears with more teeth available? going from 19 to 21 is only a 10% change when I think I need about 30% which would mean 24 or 25.
any ideas? or should i rip apart the transfer cases to swap the gears...
Current setup:
