- Jan 3, 2026
- Москва
- State - Country
- N/A
- Other
- Bmw g80
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Manual
Where does the 2004 Ranger manual transmission take speed?
It's not on the mechanical gearboxIt's usually on the driver side of the transmission. Sends signal to PCM, then to speedometer. I THINK sometimes they may be on the transfer case. It's not on the manual transmission. It's not on the transfer case. After much research, I found out that the speedometer uses data from the ABS sensors and the sensor in the axle.
Да машина сшаI assume you have a US ranger because you put 4.0, but based on location, you're not talking about an international Ranger, right?
If it takes the speed from the output sensor on the gearbox, then what speed it shows in reduced gearInteresting. So like everyone's already covered, only '98-'00 should be deriving speed from the rear diff ABS sensor. Earlier is a gear-driven sensor on the trans/tcase, and later is a magnetic pickup on the same.
But, for a trans swap, I guess they could have built whatever.
If it takes the speed from the output sensor on the gearbox, then what speed it shows in reduced gearit means that the speed is not taken from it
Датчик на механике стоит меж раздаточной коробкой и кппCan't say I take your meaning. In these trucks 2wd will be on the trans and 4wd on the tcase, so you're always after any variable gears, but I agree it's also not that weird for a speedo to just be off in 4low.
На выходном валу , а значит на пониженной передаче он врет на 2.43
Но он так не делает, значит не он мерит на машинах с 2002-2009
The sensor on a manual transmission is located between the transfer case and the gearbox. It's on the output shaft, which means it reads 2.43 in low gear. But it doesn't do that, so it's not the one measuring it on cars from 2002-2009.
But it's not on the transfer case on these trucksOn a 4x4 truck, the speed sensor is on the output of the transfer case. It should read correctly in any gear.
