Speed sensors
Москва
N/A
Other
Bmw g80
Vehicle
Drive
Where does the 2004 Ranger manual transmission take speed?
It's usually on the driver side of the transmission. Sends signal to PCM, then to speedometer. I THINK sometimes they may be on the transfer case.
It's usually on the driver side of the transmission. Sends signal to PCM, then to speedometer. I THINK sometimes they may be on the transfer case. It's not on the manual transmission. It's not on the transfer case. After much research, I found out that the speedometer uses data from the ABS sensors and the sensor in the axle.
It's not on the mechanical gearbox
Through long studies, I found out that the speed on the speedometer is taken from the abs sensors and the sensor in the work
