Speed sensor question
soylent_green
Does anyone make a reluctor ring that bolts to the T-case flange with a bracket to hold the factory diff mounted speed sensor? Seems like it would be a good way to keep your speedo and trans happy after a swap to a rear axle that doesn't have a speed sensor.
I'm not sure what year your truck is, however, my 95 rangers speed sensor was mounted to the transfer case, driven by a gear inside, and when I swapped in a manual transfer case off an 88 bronco 2, it too was mounted in the transfer case and driven by a gear. I believe the sensor you are refering to is actually the ABS system sensor.
The one on the diff sends back a lower signal since it reads the slower ring gear speed.
It's actually my buddies' black 95 F-150 with the 8.8 rear.
