- Jul 8, 2020
- Redondo Beach
- 2.9 V6
- Automatic
Hello, this is for my 2.9L 4WD B2. Currently, I'm having issues with the car stalling/dying. I replaced the wires, distributor, and ignition coil and wire. After replacing the ignition coil and connector it seemed to have stopped stalling while at freeway speeds, it continues to do so cold at low speeds around town. I am almost certain it's an electrical issue and not a fuel issue due to how sporadic it is. It may be a vacuum leak, so I'm building a smoke machine to smoke it out. While hunting down broken wires I came across this guy, looking online I found that it was the speed sensor (https://rb.gy/v0vya). I found this part from O'reillys but not the connector itself which is what I think is broken.
Where can I find the connector for this? (What are the wires themselves measuring?) Could this be causing me my stalling/dying issue?
If you have any other advice I'd appreciate it, as I'm still learning about cars and am trying to expand my knowledge. Thanks.
-Hudson
-Hudson
