Speaker wire harness
H munster
1984 Bronco II
Hey guys does anyone know if the speaker harness was changed between 93 and 94 for the explorer? Bought a new deck and adapter kit up to 93 and the adapter doesnt fit the speaker harness. Oh yea mine was made 12/93 and titled 94
The 93 and 94 are the same, but remember that there are two different harnesses. One for systems with a factory amp and one without.
It changed in 95 to a completely different harness
thanks for the info- I dont want to cut the plugs off so ill swing over to the electronics store and look for a different addapaper. That web site would have been great a few years ago when some a@* stole the deck out of my BII. I guess he needed extra wiring for his project, he cut it way back in the dash.
No professional installer will cut off a factory plug. We refuse to destroy a vehicle. Are the plugs in your ride both the same size or is one a small square plug?
could be one of 2 harnesses. the non amped has 2 flat plugs, amped has one flat plug and the bastard squared ended plug that the pins never line up right in (metra 70-5511). you probably have the 5511 plug. try to pick up a 70-5514, it has the eliminator harness in it too for about the same price $20. the amp is located under the right (p/s) rear interior quarter panel. it will sound better with an after market deck if you bypass it.
