Sparkplugs
CaliNickXLT
So whoever put the last set in my truck before I bought it was a complete tard. The plugs were a little black and oily but I just ran seafoam last night so I'm guessing that's why they were so dirty, which is also why I replaced them after the seafoam. But when it came to the gaps on the plugs I was replacing holy crap. I got anywhere from .055 and some were as low as .030. So they were all over. I put new Autolite Platinum plugs all gasped to .045 and I can deff feel ot in the pedal now. Before there was slight hesitation, but not anymore :)
Sent from my SAMSUNG-SM-G900A using Tapatalk
Well, it's always good to replace these things when their lifecycle is up, but the gap is something that can vary from plug to plug depending on a few variables...mostly heat and plug make. If you've got any kind of piston slap or whatever they call it then you could find some of them a bit flattened...
Doesn't necessarily reflect on the previous owners or their mechanical ability...just happens sometimes. The selection of plug brand might come into question as many try to save a nickel here and there only to cost themselves way more in the after effects of poor choices...
Even that can be a carp shoot with quality control taking a hit with many companies...especially those who outsource over seas...
You might want to check the pedal play for some added feel to the truck...if the cable stretches on the fuel pedal it can feel like your truck is on its last legs...or slower than the 3.slow has been given reputation for...only takes a few zip ties to fix and works great...
Just search for "zip tie fix" or similar and you should find a post in the Tech Articles...worth the effort just to know...as it has made many on here appear to be much smarter than we are with friends and family...lol
The truck was well taken care of I got complete service records for it when I bought it. None of them were flattened and they were Motorcraft platinum plugs so I was assuming the gap should have been .045 being oem plugs. I already did the zip tie only took one I did that the day I got her along with switch to synthetic oil and an air box mod to let her breathe. Next is to install my new shocks. Should be kind of intrasting because they were for my brothers full size bronco.
Good stuff! I think you will be good to your Ranger...
Just curious, but what airbox mod are you looking at? I'm asking because one of the trucks I recently purchased had the 3.0 that I was considering for my Ranger...didn't do that but I got the airbox from it and it had a K&N filter that looked very new...but no other mods were done that I could tell...
So...long story longer...I'm using that box with the 2.3 MAF and I moded it on the bottom to take a 4" pipe (not finished yet) that will go under the battery tray on the passenger side...I'm hoping to get cooler air from where I'm putting the air in pipe (4" aluminum that had a round K&N filter on it)...
Anyway...I will post pics some day when I figure out a build thread for it...almost finished now so...should be soon...
I just took the hole where air come in and changed it from the tiny looking 2" hole to a bigger 5" hole roughly. I also have a KnN drop filter biut this is just to allow more air to flow. I still have the stock box. Just made a bigger hole. It seems like it helps a bit. You can actually hear the motor now when I drive.
What's the purpose of using the 2.3 MAF?
