- Feb 28, 2001
- Dayton
- State - Country
- OR - USA
- Drive
- 4WD
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
ok, my truck has a bad habit lately since it's been warmer...
first off, engine has around 175K on it, '89 engine management system, haven't checked the codes lately (CEL is on, but I fixed the O2 problem since the last time I checked them so it's just still on I think).
problem is it pings like crazy sometimes no matter what gear I put it in to lower the load on the engine, it has been worse since the engine has been running warmer (heater core blew a while ago, just fixed it, wasn't much higher than it is normally), it's not happening all the time... an example of what it's doing is a hill on my normal commute I usually take it in 4th gear at 55mph (3000 rpm), but it was pinging, so I threw it in 3rd which is 4600rpm at 55mph since I figured that might help at the HP peak. I know the radiator on this thing is friggin tiny (about 1/2" thick), if I had to guess at what it's getting to I'd say 205ish degrees if it normally sits at 190
in the past I've gotten EGR position sensor faults on the KOEO test, and if I went out and tested them now I bet I'd get it again, might try tomorrow.
so, any ideas?
Thanks!
so, any ideas?
Thanks!
