Spacer Lift Now Camber Problem
daniel3507
NE Oklahoma
2.3 EcoBoost
Im assuming this is normal (hopefully) but just want to make sure. i just installed my 2'' spacer lift today and now my camber is out of whack. this is normal right? just need to take it in for an alignment?
Yes, this is very common with TTB. The alignment shop should be able to get it pretty close to normal with the stock alignment bushings. If not, you can have them replaced with the correct ones.
any idea how much it may cost?
To just do the alignment it should be in the hundred dollar range.
