Soon to be mine! V2.0
Shouldn't matter, if anything it might require a 2wd grill to mutilate. Find someone to trade and your golden.
Grills cracked, in 2 spots. one spot is superglue'd and zip tied together, and the other is just there.
has f150 leafs in the rear i guess, that's what they said and it def is stiff back there when you hit a bump ( there is a lot of those in my drive way :bawling:)
BTW is the drivers side seat supposed to fold? ( so you can get back in the extended cab) it's got the power air stuff in it.
has 238k miles. has a reallllyyyy bad shake at around 70ish. gonna rotate and balance the tires but idk what else i would need, and i won't be driving it anytime soon so i guess that will have to wait. slips a little going into 2nd ( like they said) and reverse gotta rev it a little before it goes. looks like the trans is overfilled tho so i'm gonna check it in a little bit. overall..even if i have to put a new trans and an engine in it...i'll probably only have a little over 2k into it and most trucks around here are 2500-3k for a truck like this with no lift and street tires...so i think i got a decent deal!
tailgate is rusted out..completely. basically the whole bottom of it is gone. the grill and trim were painted a silverish color. 4x4 works, low range works! needs U-Joints i think because it growls pretty bad in 4x4. it's got double windshield wipers ( O.o they make those? ) aftermarket radio but no aux port so i think i'm gonna give put it in my moms van and use my other radio from my old car so i can use my phone for music. found some lights in it that look like they'll fit in the fog lights part ( none in atm) so i might wire those up later!
Got about 13-14 mpg on the way back, hopefully i can get 16 out of it when i fix the misfire and do an oil change.
Only the passenger seat moves up for the super cabs. Also, if your shake is really bad, it could be a number of things. Do the U-joints, and get the tires balanced and that will tell you a lot. Might be a bent wheel even. What do you mean by double wipers? Are you talking about the units with two blades?
yep. never knew they had double wipers! and i guess i'll have to swap in a seat that does move forward...it will annoy me if i don't.
The double wipers are sold at some Autozone's. I had some once and the snow kept getting stuck between them so I trashed them.
sounds like a weird design..what's the point? Single ones seems to work just as well.
They add 30-40 HP, but only when used on Hondas.
Somebody probably figured if you have twice as many blades they'd do twice as good a job, without realizing there are companies that actually make good wipers.
What sucked most about those wipers is they were cheesy plus they made them a real bright color so everyone knows you have cheesy wipers.
These ones are black, but they painted the wiper arm silver, I got a lot of spray painting to do!
