how do you like the creepy crawlers?, put some jeep springs on that thing! good looking rig tho.
Lookin good!
You cannot go with a soft spring with TTB without it getting tippy. There is no forced articulation to hold the rig upright and softer springs will make it worse. I built up to 16" of travel with TTB fullsize Bronco and 37's. Snapped three u-joints with 37's Dana 44 TTB playing in the rocks. TTB is good for mild rocks and going fast, not for crawlin'. Wait till you drop one of the front tires off a rock or into a hole. You are counting on the spring to hold you up and catch you when it is extended and can't. A solid axle is forced down when the other side is pushed up and will catch you.
If you look around on here you will find many doing all sorts of crawling with a TTB and minimal carnage.
Obviously one ton stuff is going to be stronger, not that many make the jump in RBV land. Some do but it isn't the norm.
