brplante
i had to replace my battery cable, but the guy at the junk yard gave me a different one and told me it would work.
the stock cable (negative) went from the battery to the frame under the motor, and only had a ground cable on the battery end, and went to the frame beside the silanoid(sp).
the one he gave me also had a ground wire coming off the bottom end, can i go ahead and attach the bottom end to the starter and use the small ground wire to go to the frame?
and also, this may be a dumb question but can i use 1/2inch square tubing to replace my body mounts to get a small body lift? i dont care about the ride comfort as long as it is effective. i know i would have to get new hardware.
sorry for the stupidity, ive never been mush of a mechanic and im trying to learn...
