pcollins
- Mar 19, 2010
- Automatic
ok, so i'm in a bit of a bind here. lets start at the beginning to get a full picture:
Last year about this time, before i bought my ranger (1997 4.0 V6, 5 speed) we changed the 5th/Reverse gear at the shop. upon putting it back together and bleeding it, it got chocked full of air (yea, we were dumb, forgot to fill the resevoir) so we tried to bleed the air out of the system, but no success. so we figured bad slave cylinder. Got in there, replaced it, bled the living shit out of it, and it finally worked right. So now this is a year later, and i'm having some issues.
When the engine and tranny get up to full operating temp, the gears will not engage from a stop. 1st is impossible and reverse will grind. It ONLY does this at full Op temp. I'm thinking bad pressure plate springs, because that assembly wasn't changed when we had the tranny out, and the heat could screw with them. But could another option be the master cylinder (due to it being full of air at one point)? I want to say no to the master cylinder because heat expands brake fluid, and if it isn't disengaging at full op temp, that doesn't make sense. because the fluid would expand and disengage the clutch even more, No? I need some opinions on this...i have a clutch kit on the way, but i'm thinking about changing the master cylinder first, but i really don't want to because if that doesn't fix it, i'm out $100. There are no leaks in the Hydro system. i never lose any fluid. As far as i know these clutches are auto adjusting.
Thanks Guys.
Post script: been doing some research before i posted. i guess these master cylinders are impossible to bleed while in the truck. you guys reccomend a bench bleed?
Thanks Guys.
