misterW
- Feb 15, 2010
Spark tester attached to the coil isn't showing a spark.
There are two wires leading to the coil: a pink and green one, and a yellow and brown one. the pink and green one shows 12V with the ignition on and the yellow and brown one shows nothing. Is this right?
Also, attached to the bottom of the bracket supporting the coil is a small gray cylinder with a black wire leading to it. What is that gray cylinder and what should an electrical test of the black wire show?
Thanks in advance!
Thanks in advance!
