Cees Klumper
- Nov 4, 2019
- 2.9 V6
- Automatic
- Total Lift
- only lift is from the oversized tires
- Tire Size
- 235/75 15
Appreciate any pointers here. Two days ago, I hit someone from behind, at about 20 mph. Lucky for me mostly, the vehicle I hit had a very beefy trailer hitch, one of those square tube receivers, that spared them any damage, and 'only' bent my front bumper out of shape. We concluded no need to exchange insurance info, and went our separate ways. For me, that was a 2-3 mile ride home. I did have to reset the inrertia/fuel cutoff switch, as the bump had tripped that.
All seemed fine, as usual. Only at the very end of my trip home, I started to notice the ride felt a lot more jittery than before, I was feeling every bump and crack in the pavement and it seemed to be coming from the rear. It was so noticeable that I even thought I was riding on a flat tire.
But no, tires properly and evenly inflated. Checked the shocks (front and rear newly installed 9 months ago) - all seem good, bouncing nicely. Checked the body mounts, torsion bars, rear leaf springs, front springs, all other suspension components I can get my hands on - nothing seems off, loose, bent or anything.
I thought I might be imagining things, but on my first trip yesterday, it was again so noticeable that, again, I pulled over to check for a flat rear tire - that's how bad it feels. Before, this truck was buttery smooth.
This morning, I pushed with my foot on the top of the rear tires, 'inward', and noticed distinct movement/play and a clear clunking sound. Not good, could this be the cause? But why so sudden, and how could this at all be related to my fender bender? Seems impossible? Coincidence? Anyways, took the wheels and brake drums off and there was end to end play on the axle shafts of about 1.5 mm. Not a lot, but who knows, if the rear wheels can move sideways, maybe this explains the jittery feeling over bad surface? I then checked the differential fluid level, for the first time since getting this truck, about 1 year ago. 450 ml too low. Hmm, not good either (no leaks though, so how did that happen?). After topping up and test driving again, the side to side play in the rear wheels seems gone, but the ride is still as harsh as before. The truck has 235,000 miles and likely the original differential and bearings, not sure.
I still need to double-check front wheels/suspension/bearings, and the rear wheel bearings. But there are no grinding noises when driving, on smooth surfaces it rides just fine and quiet. It's only on not-so-great surfaces that the ride has suddenly become really jarry and bad. Vibrations at low speed that weren't there before, on bad road surfaces. It feels as if all suspension rubber was replaced with super hard polyurethane race stuff - in the rear.
Any tips appreciated! Bad rear wheel bearings? Slightly bent front frame rail on the side that got the most impact (I hit the hitch slightly off center). Frame seems fine, eyeballing it, and the impact was not THAT major (ordered a new bumper). Have not taken it on the highway yet. Could the rear shocks have gone bad from having been extended super-quickly as I hit my target and no doubt the truck flipped up at the rear? Seems unlikely, but then what explains this?
Many thanks for any pointers, I am at a bit of a loss.
