ecgreen
- Sep 21, 2018
- Dunbarton NH
- 2.9 V6
- Total Lift
- 3"
- Tire Size
- 33
Hey guys,
Still troubleshooting my electronic tansfer case. I went through the diagnostics in the Tech section (thank you whoever wrote that!). I passed all tests except the last one. It seems that my module is only sending 5 volts to the switch. The diag sheet says it should read 12 volts when you backprobe the module and turn the key on and press the 4x4 button. I am only getting 5 volts. Is this a thing or did I do something wrong? I am also not getting any voltage on the orange wire on the shift motor side of the transfer case connection. I am thinking a bad shift module. Thoughts? Hope I was clear enough.
