<< SOLVED!... P0171 & P0174, FTrims WAY positive, O2 sensors "bouncing" full range!...
fixizin
FoMoCo is forcing me to buy a 'yota
⭐Supporting Member
Fort Lauderdale
FL - USA
Drive
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
... yet it's running fine and idling normally... hmmm... vacuum leak?
DATASTREAM(idle): LTFT1&2 rock solid at 25.0%, STFTs bubbling in the high 30s, occasionally breaking 40% !! O2 sensors rapidly changing from 0.06V up to 0.88 :icon_confused:
Also fuel mileage seems to be suffering, down around 11MPG around town, but no Rich smell or hot cats... Err, umm, WHERE do I start?
(Recently cleaned MAF and swapped air filter--no change... however, WAY overdue for a Fuel Filter... )
OK, unplugged the IAC at WARM IDLE, and ZERO change... HOW to check for vacuum leaks? Smoke from an incense stick would probably be useless with all the draft from the belt-driven fan... will first carefully check the "elephant trunk" intake tube... lotta connections and "joints" there... 🔎🔬
Try the old brake clean/carb clean trick... Something aerosol and flammable (some brake cleaners aren't flammable anymore 😤) Spray around the intake until you hear the revs kick up.
OK, here's a pic of the breather hose connector, at about the halfway point on the snorkel/intake tube, looking rather aged and CRACKED... guessing that's the IAT sensor next to it...?
Should probably use some tire-shine/Black Magic on Ye Olde "elephant trunk"... :stirthepot:
Sounds viable, since given the OBD #'s, it's a LOT of air bypassing the MAF... OTOH, if it turns out none my sprays are flammable, I could drop the serpentine belt and run it for just a few minutes for the smoke test...?
YouTube has a good many diy smoke test machine videos. I did one and found my evap system leak in five minutes. Not hard to build and not expensive.
OK, with a well-warmed engine (plus it's August... in Florida, lol), I revved to 3,000 and LTFTs dropped from 25.0 to 16-17 range,
more dramatically, STFTs dropped from from high 30s to near zero, even going a point or two NEGative... (isn't that near normal??)
What does that tell ye RKIs?? (Thanks in advance...)
PS: I'm guessing the principle here that a leak is of fixed size, but since airflow increases linearly with RPM/throttle-plate opening, the higher the revs, the leak becomes less % of total airflow, and thus introduces less error for the ECM to compensate for...? ... anyway, sounds good to me... :sneaky:
In related news, while my NON-chlorinated save-the-planet Wally World generic brake parts cleaner is ambiguous about its sexuality flammability, my CRC-brand MAF Cleaner is certain that it's HIGHLY flammable!... but I'll probably go the smoke route, in case leak is underneath, etc... plus that CRC stuff is pricey!
You said you already changed the maf sensor. A stuck open egr valve on a maf engine will cause the engine to run lean.
Close, I changed the AIR FILTER... merely cleaned the MAF sensor... will have to review EGR theory, but isn't the EGR basically wide open when engine is warm and revving?
Force the egr valve to open at idle. The engine should stall or almost stall. If engine does not get rough it indicates a problem with egr system.
OK, I've got one of those hand-operated vacuum pumps, hopefully have the right fitting to put a test "tug" on my EGR...
... but what's the theory here, that my EGR is stuck CLOSED???... (how would that make it run LEAN?...)
To eliminate a fuel delivery issue, graph your 2 upstream oxygen sensors on a wide open throttle run. They both should read above 800 miiivolts at wide open throttle. Do not get a speeding ticket- do the check in a lower gear.
that allows fresh air into the valve cover/crankcase which is later removed via the PCV valve and sent back into the intake.
the hose from the PCV back to the intake can get very hard, cause leaks.
